Need a low cost 4 amp, 48 volt, stepper drive | | Hey guys, I have done so much research that my head is spinning. I have purchased a set of Superior Electric Slo-Syn series M092-FD08 steppers for my Grizzly mini-mill cnc project. The motors are rated at 3 volts, 4 amps and I will be using a 48 volt, 10 amp power supply.
I am looking for a low cost stepper drive that can take 50 volts or more and handle 4 amps per phase. I have looked at most of the drive makers that we know of and a lot of them only handle 2.5 or 3 amps, or the voltage is not high enough. Is my only choice to go with Gecko 201 drives?
From what I have read here, the recommendation is to go with a half-winding wiring scheme for fast stepping and higher power output. Is it not a good idea to go with a full-winding scheme and get a lower power drive? How about some of the unipolar drives with less features? They seem to have the right current handling capacity.
Thanks for any help that you can offer.
Mini-Miller |
