Originally Posted by caleb105 OK....here are the assumptions I am making:
1) The max # of flutes on an endmill would be 4 (perhaps this is wrong?)
2) The maximum chip load (roughing) is .005"
3) The maximum RPM for an X3 is 2000 RPM
So....the formulas are:
IPM = RPM x IPR
IPR = Chip Load x Flutes = (.005" x 4) = .02"
Therefore:
IPM = (2000rpm) x (.02") = 40 IPM
So why should my cnc mill be capable of 100ipm + ?
What is a good maximum limit for IPM on an x3?
Thanks! |
youve left out alot of data.
the size and type of cutter, along with the type of cutting and material being cut will impact the feed per tooth. for example 2 flute 1/2 emd mills can range from .001 recomended feed in HSS to .04" (not a typo) on some fancy carbide ones for aluminium cutting.
2000rpm is definitely a limiting factor though and with typical hss tooling 40ipm would be optimistic on cutters under 1/2". you can certainly force the machine faster (ive done that by accident), but the tool and workpiece wont thank you and neither will the gears in the spindle head.
