justgary,
I received your "iges" files and followed through your step-by-step instructions. My first question to is "HOW ON EARTH DID YOU FIGURE ALL OF THAT OUT????"
The simulation seemed to work where the rotary axis rotated a full 360 degrees for each profile increment. The only thing I noticed was that the rotary axis was not operating synchronized with the linear axes. I'm sure that wasn't the objective with your trial but I wonder 'how' and 'if' that can be done.
Also, when I posted the code, there were no rotary axis moves in the file. I think you mentioned that you had that same problem but found the fix. Can you tell me how you did it? |
