Thanx guys (no grls i prsme)
I will start hunting for the stuff.
Just clarity on the servo size.. There is a big difference between 40in-lb and 650 in-lb
I like to over engineer rather than under, but there's a jungle of stuff out there.
Does servo's turn freely when not under power? (will i still be able to use it in manual mode). Interfacing with the pc, i hear of printer ports with breakout boards- that i understand, but do you then still need the (black box, mach 2 etc). Also i deduct that i should look for servo drivers that accepts step and direction inputs, what other inputs can you give a servo driver then, and is the size of the step user configurable?
Thanx for your replies, i feel something big coming.. (no not that)
