Old 12-07-2004, 09:27 PM
ger21's Avatar
ger21 ger21 is online now
Originally Posted by Hack
So the way I am adding this up, I will need a power supply of about 17 or 18 amps?
3 motors at 2.8 amps per phase - dual phase motors = 16.8 amps
what about volts? How many for the motors I listed above?
Thanks again
Depends on the driver. With Geckos, for each motor you need 2/3 the rated current for a single phase. 2.8*.666 = 1.86a/motor. For geckos. Xylotex is similar. I'm assuming Automation Direct is as well, that's why they sell the low current supply. You never know, though.
Volts is a different story. Most motors have a rated voltage. You want to normally run several times that voltage, depending on the application. Some people will tell you 10 to 20 times the rated voltage. More voltage gives you higher speeds. It also gives you hotter motors. The best advice I've heard is to run just enough volts to give you the speed you want. Figuring this out can be tricky. The Xylotex makes it easy. Realistic 28-30V max, which should be fine for just about any motor.
And whether you use 1 or 3 motors, volts stays the same.
