Originally Posted by Hack
If I do return the driver, any suggestions on what to use instead? The xylotex board is rated at 2.5 amps per phase max and the steppers are rated at 2.8a per phase. I assume that this means it wont work?
How much better off from a compatability standpoint would I be if I just bit the bullet and bought the other items from Automation Direct?
Thanks all |
Those steppers should be fine with a Xylotex. If you run them at 2.5a/phase, you'll get about 90% of the rated torque. According to Jeff at Xylotex, if you run steppers at their full rated current, the microstepping won't be as smooth. He recommends a little less than full rated current for best performance.
Not sure about the automation direct drives, but the Xylotex will work fine with a 4-5a power supply, Due to the chopper design it's very efficient. You can get a 28V supply from here:
http://www.mpja.com/productview.asp?product=15493+PS for $30.
Keep the motors, buy the Xylotex and a power supply like I listed above. Probably 85+% of the performance for 20% of the price.
