Originally Posted by Jason3 Almost! I built a spindle with a 3 Hp Magmotor like the combat robot guys use...the motor was ferocious... Rated speed at 24v is 6000 rpm, and it has tons of torque.
If I could keep the motor cool, I would absolutely use it on something like the Sherline spindle.
You can control the brushless RC motor controllers with a servo tester - http://www.robotcombat.com/products/RL-SRVTST.html
Did you consider using a servo to drive the spindle? Everybody I've heard of doing that has been very pleased with their performance.
Best regards,
Jason |
Yes, I've thought about using a servo tester, I think I have one around here in my tons of RC stuff...
Hmmm... a servo spindle would give me instant rigid tapping ability...
Your 3hp combat 'bot motor sounds good, my current spindle setup is fan-cooled, but I guess I'd need more than just a fan... maybe a Peltier or water cooling?
Arrgh...I think I'll wait a bit on this one. When I get into PICs it'll be for robotics, I guess I won't torture them in my mill, at least not right away. Dealing with a learning curve AND a destructive environment sounds expensive.
Yes, running something like a 3/4" two-flute through aluminum at 10,000RPM and 100IPM is a lot of fun... but noisy.
