Old 02-02-2009, 04:17 PM
Geof Geof is online now
Originally Posted by project5k View Post
..So, if i'm gonna go the route of making half moon clamps, (vice jaws) then i could use compressed air and some short throw, medium to large diameter(I'm thinking 1 inch) air cyls and just do it that way.. i have 185psi compressed air on tap at all times...
185psi air, that is high!!! But not high enough.
A 1" diameter cylinder will give you about 145 pounds of force closing your air vise, not enough I am afraid. You would need something like a 3" or 4" diameter cylinder.
If you do not have a vise make yourself some halfmoon clamps that are closed using a couple of bolts, just like a split clamp except one half is machined into your plate.
