You can configure Mach 2's step and direction output to a number of different pins on the 25 pin printer port. You need to find out which pins your Camtronics controller uses. Once you know this then you can configure Mach 2 to match it.
__________________ Thanks
Jeff Davis (HomeCNC)
http://www.homecnc.info
(Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
