Too much RPM, I'm sure your miter saw was intended for wood.
How thin are these pieces your cutting? I'm sure you wanted a cold saw until you saw the prices?
A small verticle band saw with a cross slide would probably be in your price range and safer to use, probably get a better finish also, if that matters for your application. Horizonal band saw would be better and a cold saw would be best. |
