Originally Posted by Brewmeister ok, I'm not sure I understand the header. Is the DX, DY, DZ the zero point?
Also, I don't see where you are setting the 5mm cut depth.
It looks like Z=2 is the clearance, and DZ=18 could be the clearance above Z0?
I assume XG0 is a rapid move, and XL2P is a cut move
Also, the example you posted, I can see the shape of the logo, but the shape is larger than what I can fit in 600mm.
Anyways, I programmed this with the XYZ zero point at the lower left corner of the "A". Let me know how it works out. This is just the finish profile with a 1.5mm cutter. I also have a rough pocket with a 9mm cutter, and another path that roughs out the corners missed by the 9mm using the 1.5mm.
The header is the size of the panel DX= Width, DY= Height, and DZ= Depth, of the panel
I do not set the depth 5 mm but 2 mm, DZ=18 is the thickens of the panel
sorry for my bad english
