IF you try to directly cut the stock with laser, I could see lots of distortion potential, BUT if you sandwich it tween .005 or 0.03 hard steel shim stock, different story. WE cut valve spring shims all the time out of .005, .015 and .030 and they are perfect absolutely no distortion
Re post 6 - while you're struggling with the shim stock, the laser shop could be doing the work in parallel path sort of deal. You'd make a quick 15-20 percent for doing almost nothing. |
