Thread: WinCnc trouble
Old 01-28-2009, 10:16 AM
SCRAPWOTSCRAP SCRAPWOTSCRAP is offline
SCRAPWOTSCRAP is on a distinguished road
Well, quick fix would be to pull the program into text editor, word pad, note pad, MS Word and edit the program so only one command per line.
Think you can also edit it in BobCad in the NC window, just place cursor
after each g-code command and hit carriage return (enter).
Better fix....If I recall correctly BobCad has a provision for you to edit "program start" and "program end" macros in the NC portion of Bobcad and save those so your program start and end would have only one command per line, thus when generating future programs they would start and end correctly.
If you need help with that you might try posting in the BobCad forums explaining what you would like to do, and I'm sure someone would help you fix your Program Start and Program end. Or contact BobCad. I'm not the world's foremost expert on BobCad, but I think this is fairly easy fix.
I would check the end of your program also, it might have multiple commands
per line, check before running.
