  #12   Ban this user!
Old 01-27-2009, 10:03 AM
m8kingit m8kingit is offline
m8kingit is on a distinguished road
Al, do you think i will blow a 20 amp breaker from the power surge when i power up using your advice on 25000 mfd filter caps. Keep in mind that eventually, I'll want to use both taps at 40v 19 amp at the same time, also, should i use a resistor connected to the caps to bleed them down when powered off?
Mark
