Old 01-24-2009, 01:39 PM
Geof Geof is offline
You probably destroyed the mills because they were re cutting chips.
Pre drill much larger so you are only removing about .05 maximum with the mill. Run at around 200SFM with a feed of about .001 per tooth and use a four flute cutter ramping down helically at about 0.1 maximum per circle.
Do not pilot for the pre drilling use a split point drill in a single pass.
