Old 01-24-2009, 10:00 AM
Horsedorf Horsedorf is offline
Horsedorf is on a distinguished road
You might want to make sure the configuration bits are set correctly for the pic. Also, the pic that you read from, might be using the internal oscilator which means it might have to be properly trimmed to make it run at 4mhz or whatever internal clock rate the thing is running at. Depending on what the pic is doing in the system, the code may not be very large at all, a few hundred bytes or less.
