I just ran into the same problem, but with a twist.
I had no PGM files on the harddrive, so when I tried to load a file, it would check the harddrive and the floppy, then tell me that there were no files. So it never brought up the window where you could select F4 to see the floppy drive and F5 to see all files. Definitely a bug.
So I created a PGM file with one line in it, and then I was able to use F4 and F5 to find the TXT files.
Thanks for the help, though. I wasn't able to figure out my problem without your solution. |
