Old 01-19-2009, 05:43 PM
PhoenixMetal PhoenixMetal is offline
PhoenixMetal is on a distinguished road
NT35 Taper - Same as BT35?
I just purchased a used Kitamura Vertical Machining Center, and I'm not sure what taper tool holder it takes.
The manual says it takes No.35 Taper, which doesn't quite help me to determine wither it is CAT, BT or something else. The model numbers for the Kitamura-brand toolholders listed in the manual all start with NT35. So is there a taper style called NT35? If so, is this the same thing as BT35?
I do know that other Kitamura machines use BT35, but I suppose it is possible that they offered different options so I want to be sure.
If any of you have any information, I would greatly appreciate it.
