Thread: Old Wire EDM
Old 01-19-2009, 03:21 PM
Helix60 Helix60 is offline
Helix60 is on a distinguished road
Originally Posted by glbreil View Post
It is a Leblond Makino EC series, but the control is an MCW II and I have not been able to find any information about it anywhere.
Any idea on how much it would cost to get one ready to run. Filters, Dielectric fluid, etc.
Filters are available on Ebay, Last I saw about $30 each. Sodick uses the same filtters. You will need two per filter tank.
Dielectric fluid is just clean water run through your DI resin tank. Resin is also available on Ebay.
Other sources you can find on the web. Do a search for "edm supplies", you'll find a bunch.
Cost wise figure about $400 minimum, which should include some wire. Makino's guides are not Cheap. About $1000 a set but they last 10 times longer than most others. You may also need new Carbide Power Contactors. Not sure on the price due to differnt types.
Regards,
Heli
