router bearings | | I'm in the process of designing my own router, similar to the hobby CNC one. It will have low utilization, so wear isn't to much of a concern. Mostly will cut balsa and light ply, but maybe some softwoods also. I've got a Rotozip Solaris I plan on using for the router.
I just bought two pieces of 3/4" drill rod from KBC (I'm lucky their 5 minutes away) that I plan on using for the x axysis. Rough dimensions for table top 36" x 18". I have a piece of glued up hard maple strips that is very stable and strong that I plan on using for the basic bed. The rest will be baltic birch plywood of appropriate thickness for the part. My son has played roller hockey for years so I have some of those bearings. My question is on the x axysis, I'd like to use two bearings on top of the 3/4" rod and use brass bolt ends (either 1/4-20 or 10-32) for lateral bearings and bottom bearings. By using T-nuts or brass inserts I can get snug adjustments. I figure that the weight of the Y,Z axysis mechanics and the 2 lbs of the router will place the most force down. I wouldn't think a lot of lateral force force would be placed in while cutting. The other thought would be to use some exotic (LV) hardwood for lateral and bottom bearings. Just can't commit myself to the cost of commercial linear bearings. But I am a firm believer in the KISS principle. Am I going to be in for a surprise?
Thanks,
Phil |
