My mill motor died repeatedly. The internal starter-circuit points keep welding itself and to run like that is horribly loud and will burn up the motor. I see that Devinchi found a replacement. Details please!!!!
BTW, I tried the replacement from Grainger that was recommended by Shoptask. Required drilling on the Shoptask frame. Also the pulley they recommended didn't fit...spacing between the pulley tracks didn't match that of the existing pulleys.
Only option now is use the original and that seems like a non-answer.
Reason: adding info
