  #11   Ban this user!
Old 01-14-2009, 11:30 AM
Astonlee's Avatar
Astonlee Astonlee is offline
Astonlee is on a distinguished road
Run-out error
I found sometimes it's not the collet that the problem, often as not by just rotating holder by 180 degrees you cure it, but it's not so easy has that with a machine that using CAT-V (Din 69871) but at least you can test toolholder by removing the larger drive key from spindle and manually loading tool.
