Do you enable or disable the 4th axis in parameters somewhere? Any controller that has 4 working servo amps is going to miss the motor that isn't hooked up, so I'd say you have to disable that servo amp somehow.
__________________ First you get good, then you get fast. Then grouchiness sets in.
(Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
