Old 01-13-2009, 05:12 PM
ViperTX ViperTX is offline
ViperTX is on a distinguished road
If this is an RS232C connection, then unless someone knows the cable pin out for the handshaking the easiest thing to do is get an RS232 break out board.
Pins 2 and 3 on the DB25 will be Transmit/Receive and Pin 7 will be ground. There should be a Terminal Ready pin...don't recall which pin that is. Google RS232C.
You say the other side is a 3M connector....not a Centronics style printer cable?
