Under Configure> Configure Axis, you can set the parallel port, and step and direction pins for each axis. MAKE SURE you have the correct port set.
Also, you should download the latest Hotfix from the TurboCNC Yahoo group.
__________________ Gerry
(Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
