Well this enclosure isn't nearly as fancy as some that have been posted here, it should work.
It took 40' 1x1 alum tube, 40' 1x1 alum angle, 3 sheets of coroplast, 3.5 tubes of silicone, over 100 pop rivets, and some time. I hope some of the coolant will stay in the machine now!
I made the front as wide as the machine, and removable sides to keep the abillity to run oversized parts, and have forklift access. The hardest part was trying to keep things sort of straight while utilising the chip extensions, as they flop all over the place.
I have 2 big "cheats" in this design, 1. On the left side where the servo sticks out, I only made a 3 sided box and overlapped the 2 panels. 2. The enclosure is rectangular and the factory chip pan has several funky angles, to fill in the gap I simply left 2 flaps on my door to cover them.
I also siliconed a piece of coroplast to the side of the panel to keep some of the spray off. Some day I may lengthen the wires and move the control out another 12".
__________________ On all equipment there are 2 levers...
Lever "A", and Lever F'in "B" |
