Old 01-10-2009, 08:34 PM
keebler303 keebler303 is offline
keebler303 is on a distinguished road
Need Help -> Eagle and PCB-Gcode
Background:
I have been drawing my layouts in cad and generating isolation toolpaths with cam. I have decided to switch over to eagle/pcb-gcode to make it easier to make layouts. Working on my first try now, I'm a newb to both.
Problem:
I am trying to make a single sided board for through hole components. I have a few components layed out and traces between them on the bottom layer. I ran PCB-Gcode to get my toolpaths. The problem is the isolation for the traces is on the bottom as it should be. However, the isolation for the pads of the components are on the top layer. The result is that the traces are not isolated on the bottom layer, which is the only one I am milling.
I can elaborate if this is not clear.
Matt
