How do I set Parameter 592 for G 83 Cycle | | Fanuc 0TD control on a Turning Center.
I am using the G 83 Cycle to peck drill in Z. Tool feeds to set depth, retracts to remove chips and returns into hole for another drilling feed distance. Problem I am having is when drill rapids back to depth that it retracted from for another feed, there is no clearance from the bottom of the hole to the drill point. It goes right to the depth it came from then changes to feed. Manual indicated that this clearance distance can be specified by setting "Parameter # 592" but then does not tell one how to do that, or at least not that I have found yet. I have found a parameter screen but am not sure which data to change. Anyone familiar with this ??? |
