Old 01-06-2009, 09:31 AM
mitt mitt is offline
mitt is on a distinguished road
if there is absolutely no sign of starting, then there is problem with power. check voltages on all power supplies.
check voltage on wire, that connects to power button, under operator panel. then follow that wire, by drawings until you get to defective component.
is possible, that your CRT stopped working? i saw your topic reffering to that problem...
drives normally get power when controller boots, or when you switch on the main switch?
