Originally Posted by automizer Im assuming this is going to be just a simple single phase 120v cnc controlled on off switch.... Maybe I shouldn't make this assumption and just sign up for one |
Single phase 120VAC at 15 amps; they plug into a standard three pin AC outlet and have a standard socket on the back. They can be used to directly control motors and can also be used to control larger multi-contact relays for heavier equipment.
There will be a power on/off switch with an indicator light, a three position relay on/enable/disable switch with indicator lights and circuit breaker on the AC socket.
We will also get some with the M-FIN wiring for sensing when an action is complete.; this will have a reset button for the M-FIN circuit.
There will be power on/o
