Thread: Problem spindle churp or squeak
Old 01-03-2009, 07:52 PM
machinetoolguy machinetoolguy is offline
machinetoolguy is on a distinguished road
Originally Posted by mls View Post
I have a 2006 haas vf 3 I've had it 8 months the spindle squeaks or chips sometimes has any one else have this
thanks Mike
If the machine is not under warranty I would say run it till it dies. In a lot of cases with Haas spindles you will hear what is called bearing cage rattle. It does not affect the part and it comes and goes. Kind of sounds like a rattlesnake on speed. LOL. If this is what you are hearing, I personally would not worry. If it is a constant sound (Meaning all the time at different speeds) you may want to have it looked into. Haas Factory Outlets have a vibration analyzer test that can tell you if the spindle is going bad. It looks at bearing vibration and other machine component vibration.
