Thread: Newbie Nube need advice
Old 01-02-2009, 06:38 PM
Rhinorider Rhinorider is offline
Rhinorider is on a distinguished road
Thanks Matt, good stuff there, you gave some good ideas. I had originally planned on just a plasma machine however you brought up a good point, if I make it for router also I could have a dual purpose machine.
If I build plasma only I will probably go the V grove route for rails, if I go dual purpose I probably go the linear route.
Drives for X axis I'll probably go with rack and pinion. Y, either rack and pinion or screw depending if I do the router build. Z, I am thinking of rack and pinion, Hypertherms machine torch comes with a rack already attached.
I think I have decided on Hypertherm 1000 cutter. What you said about the built in interface is what I suspected, pin outs that make hook up easier, plus just unplug data line and machine torch, plug in hand torch and have plasma will travel.
I will research the gantry alu you metioned as well as the motor sizes. Mach 3, and Gekos are for sure. I don't know anything about the sheet cam you mentioned I'll have to research it, any other cam software I should compare with it?
I think I will use the 4" channel I have on hand for the table, I've been thinking on size and 5 X 10 is what I have decided on. that way I can load a full 4 x 8 sheet. Yes on the water table, can't stand a messy shop.
I am building a large trailer right now in the shop, it is almost finished and ready for paint. As soon as I get it done, and make some room in the shop the table is going to be my next build.
