I have had the cover off today and checked all the air lines and connections, all seem to be good. When pressing tool release the drawbar cylinder is moving slightly, but not even enough to break the limit switch which detects tool clamped.
I wound up the air pressure of the main regulator to about 100 psi to see if the extra pressure would help release a sticky valve but made no difference. |
