Thread: Step frequency
Old 11-21-2004, 02:16 AM
drk drk is offline
drk is on a distinguished road
Step frequency
Hi, I recently changed my motors from steppers( i ran them with my self made L297, L298 driver) to some old iron core type electrocraft motors ( 60V, 16ozin) and used Gecko 340 s for that.
The encoder are renco with 500 lines ( 2000ppr after quadrature). The machine im retrofitting with these motors has a 22mm ballscrew with 5TPI.
My question to you experts is that :
1.To achieve a linear travel speed of 100-400 inches a minute, what should be my step signal grequency range.
2. With geck drives, there is no nee for tacho feedback, so while the drive makes sure that the difference between the no of pulses sent ( step signal) and those received from the encoder are the same ( position reached) what parameter controls the time the motor takes to reach the desired position and the motor speed at which it shall rotoate, is it the voltage??
