Yet another wiring question... | | Hi all-
Spent the day soldering and wiring, but I have a question (again)... CR, you said to ground the drain wire at the driver end... What exactly did you mean by this (wiring is not my specialty by any stretch of the imagination)? I bought 4 wire shielded cable for the motor cables and soldered everything up according to the diagrams, but there is a bare wire included in the cable I bought. Did you mean I should hook the bare (ground?) or some other wire to the connector on one of the DB9 pins between the resistor soldered to pins #1 and 5? According to the literature I got from Marris's fine company, those are marked as ground...
Its gettin' there... I hope!
-F |
