Richard,
You will need to change the pulse equivalent to half of what it is now.
Push the menu button then go to "Machine setup" then "pulse equivalent/mm".
Then you can change the amount for the X,Y and Z axis. These need to be set to approx half of what they are at present ie:400mm if they are 800mm etc. The Z axis may not have been changed.
Shannon.
__________________ Excitech 1530 Router owner,
WWW.REMAIN.CO.NZ. |
