Originally Posted by augusto diaz Hi, guys, I had been programing in G-codes M-codes, but must probably I'll move to
Hurco environment, if any one can tell me where I can get information about Hurco
conversational program (both late and mills) I'll appreciate.
Thanks for the time.
Augusto. |
Hurco manuals can be found on line at the Hurco website.
I program offline, but I sat in on a Hurco training class at shop that got new machines. The instructor picked one of the companies rather sophisticated parts, took a caliper and made some rough measurements since a print wasn't handly and quickly reproduced the part in Conversational. I was rather impressed as I would have drawn it up in the CAD/CAM myself. It's fairly easy given a print to work from to produce a part in Conversational given just a slight learning curve. A lot shorter learning curve than you'd have starting from scratch with CAD/CAM. Conversational will let you enter known data and it will go back and calculate the unknowns.
