I considered doing a finishing pass into the routine but decided to put it off. It's possible that I may. I may also add a spiral plunge ability as well. Working on this wizard and a screenset that I have in the works has eaten up way too much of my time lately. I'm not getting a lot else done.
Gerry, I used Photoshop for the whole layout. After I get everything where I want it I slice it up into buttons with one big image for the background. I have to create two versions, one for the on state of the buttons, and one for the off state. I have a little bit of background using Photoshop so it helps.
Here also is the screenset I have been using. The circle wizard actually started out as page two in the screenset, and still is. I broke it out to be a stand alone wizard for anyone else. The screen is actually a little different from this shot.
Because the Circle routines are actually a part of the main screenset it loads instantly so it's easy to create a roughing path then bounce right back and create a finish pass. All the values are still there.
Andy
