on the G201, if you link a motor of 6A, shall the set resistor set for 6A or 67% of 6A? |
It should be set at 6 amps, or you will limit the motors top performance. That is a good question though, sounds like something I would come up with, after overthinking a situation! LOL
The 67% rule for power supply, is because you are never going to be pulling the full load on every motor, so you dont need to have enough power to do so, but the individual motors may pull 6 amps or close every once and awhile, thats why you need to have the current set resistor set at 6 amps in your situation.
Does that make sense?
