Thread: Need Help! Haas TM-1P set up
Old 12-23-2008, 08:32 AM
Geof Geof is online now
Originally Posted by HelicopterJohn View Post
.....Also, I don't use the handles supplied with the vises. If you accidently leave one in the vise you can say good by to those nice doors on the enclosure....
It sounds like you altered the wrenches to hang down inside if you left them on the vise.
An alternate method is to make an extended handle that prevents the door on the machine closing; that way you cannot start it which the handle on the vise. Unless you are foolish enough to turn Setting 51 ON and forget the handle.
