Ok so we have a 16 station BT carousel here. If it has the old school 1 piece style finger set up it is still an easy fix. The fingers are for sure different so they will need to be replaced. The actual diameter where it grips the tool is slightly different. I have not seen one of those style setups in a long while. Sorry for the misleading info before.
I used to work at the factory back in 1994 building the carousel plates. They changed to a 2 finger set up in 92 or 93. The Haas part number for the CT single finger extractor is 22-7066A and for the BT it is 20-7166 check it out with your local Haas Factory Outlet. Hope I cleared the confusion I caused. |
