We got the Shop Sabre running this afternoon with a temporary spindle arrangement. We will be making an aluminum plate for the router but for a quick verification the mdf plate seems to work. Actually we are considering keeping the router setup available even after getting the vfd spindle running. For light cuts and engraving why use a 5hp spindle. With on six bolts to change the spindles can be swapped in minutes.
Here is a photo of the set up and also the final sign.
We are still working on getting the 3 phase voltage source going properly.
Russ |
