Anwser: Yes
In the Haas Parameters for the Y axis, it is possible with software to reverse the Encoder signals, the motor direction, as well as the limit switch and so forth, so that if it is wired backwards, you can simply tell it to read it opposite or inverse.
I have played with these settings, to no avail... still jumps, then gets the error... no matter if set forward, or backwards?
Thanks - |
