Haas VF3 Servo Over Current... after installing new motor. | | Hello,
Haas VF3 Serial number 2014 1994 model... Have owned for a year without any trouble...
I have a problem, I got the Ground fault error, which by bypassing that discovered my Y axis motor had a short... to the brush housing... I rebuilt the motor, new bearings and seal, new brushes... put it back in... then I got the Y Cable Fault error message... looking in the book, looked like it wiped the encoder out when it shorted... to ground.
So after more than a week, and much frustration... I need to get this thing going... I order in a new motor, and new cable, and installed them... I got work to do...
No..... Y Axis Servo Overcurrent... The Y axis jumps a little, about .100 thousands and stops giving this error...
I no longer have the Ground fault error, I no longer have the cable error, and I have a brand new motor...
Can someone help me with the proceedure to set up the parameters for the new motor... I think it does not know where it is... so jumps and then gets the error...
Help...
- Jeff |
