Thread: Rattle up top
Old 11-15-2004, 08:14 PM
HuFlungDung's Avatar
HuFlungDung HuFlungDung is offline
Moderator
Is there a spline drive inside this spindle? Perhaps the spline is getting worn.
You might try replacing the belt. A lack of horsepower could also contribute, depending on how heavy your heavy cuts are. If the cutter tends to slow the spindle with every tooth engagement, it could cause a rattling effect.
