Thread: Need Help! 5T punch out problem
Old 12-12-2008, 01:11 PM
eaglemark eaglemark is offline
eaglemark is on a distinguished road
5T punchout
Thanks Dan!
Yup, that was it. All is back to normal. Like you said, the file will transfer without the % at the beginning of the file, but I'm glad to have it back the way it was.
One more quick question regarding my machines parameters. I was comparing the parameter settings of my machine to the ones posted by J. Martinez for his Ikegai FX25N with the same 5T control. Number 63 is blank, then there are 4 digit codes from Group 64 through Group 99. Although many of the codes are identical between our two machines, it appears that my settings were not affected by the battery failure and remained unchanged. Can I assume that these are not parameter settings, and if so, what do these numbers represent?
I want to post the complete set of parameters of my machine to this forum so that others will have access to them in the future if needed. If those in group 64 through 99 are fixed and unchangable, then I won't need to include them when I post the parameter settings.
Thanks again!
Mark
