Thread: Need Help! HAAS VF-0 & SDNC
Old 12-11-2008, 01:52 PM
Pinball Pinball is offline
Pinball is on a distinguished road
vf0
The first thing to check is that now you are running a windows system is that your network is set to allow sharing to all devices, then you need to set baud rate to 9600 - 8 - 1. the VF0 will only work on these setting if using a windows o/s. also check that the setting for your rs232 port on the haas have not been changed by the other 'free trial software' that you have been using.
Hope this helps.
