The machine does not specifically ask for TXT files. Instead it considers these Other files.
Also which buttons to press is software version dependent.
manuals for these machines can be purchased reasonably on CDROM in PDF format at machinemanulas.net
By the way if you load a .PGM file and are in the run screen, press the minus button. You will see the G & M code program that the PGM file has been converted to by the BMDC board.
George W. |
