took a pic,
put 2 rails side by side so they can touch ends
in the middle you can see the space, you can see the space to the left side as well (little white from napkin).
the space for these 2 is 2.5mm wide, I can't put rails end to end because of the trucks, if I would do that the space would be bigger. |
