Bent linear rails - opinions ? Help ! | | I received the rails for the X azis, 1440mm long, used from ebay.
The rails are slightly bent from start to end -about 2-3 mm deflection.
20mm wide rails, 1440mm long. Is that normal and something that can be adjusted while mounting ? Or should I take it with the seller and shipping company ? Sent email to seller but no answer yet. Item description said nothing about bent rails.
Thanks,
Florin |
